how to change the token id to product name as in mixer recipe?
fakhrusy_17004283
Message 1 of 10
fakhrusy_17004283
[ FlexSim 18.2.3 ]
Greetings,
My recipe in mixer is currently as below...
based on the picture above, how to sync the token id and the mixer recipe?
Can @Patrick Zweekhorst assist me??
Can you just give me a simple program to simulate the fundamental...
Replies (9)
Message 2 of 10
patrick_zweekhorst
Hi @Fakhrusy Sf ,
The token Id is just an unique id each token gets. If you would create more tokens before the tokens that go to the mixer all the tokens that go to the mixer will have a different id.
You can probably use one of the labels on the token, or some information from the mixer. I am just not sure what information you want in your table? And since there is no model attached we can't take a look at the model to check the labels on the token
Message 3 of 10
joerg_vogel_HsH
A token ID is not useable for an order of tokens. A model may contain hidden process flows for statical analyses. Each process can create tokens. Their IDs are unique over a model, but not in a strict sequence for a process. You only knows new ID is larger then previous ID. The difference is unknown. As @Patrick Zweekhorst said, you should use a label at your token to create an own ID. Please call the label differently.
You increment a label in your process, which value you assign to any new token in your process at your own ID label on your token.
In cases where you create an amount of tokens at once more than one you have to test on your own how you can assign a right value as an ordered ID to your tokens.
Message 4 of 10
jason_lightfootVL7B4
Also you're free to rename the tokens if you just want to see something more meaningful than "token".
Message 5 of 10
fakhrusy_17004283
Alright, I understand the fundamental of token ID..
This my current statistic collector, I want to add one more column which are the "Product" column to indicate which product that there are currently processing...
How to assign label based on the production schedule and mixer table??
I attached my model as below...
Mini_Simulation_OilLubricantsV7.fsm
Message 6 of 10
Could you re-upload the model?
Message 7 of 10
fakhrusy_17004283
Message 8 of 10
fakhrusy_17004283
It is possible to do it? @Jason Lightfoot @Patrick Zweekhorst
Message 9 of 10
Add a column to the stats collector like this:
Message 10 of 10
Jeanette_Fullmer
Hi @Fakhrusy Sf, was Patrick Zweekhorst's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
