How to change the outline state color?
leelichou1112
leelichou1112
[ FlexSim 22.0.16 ]
When using the Stop object, can the displayed box color be changed according to different states?
I want to change the yellow frame to another color and customize the color according to the occurrence of different states
moehlmann_fe
Observer
Observer
You might be able to change the frame's color somewhere deep within FlexSim or by developing a custom object.
The easier solution would be to simply draw your own colored shape in the processor's On Draw trigger. If you return a non-null value in that trigger, the default draw code will not executed and thus the "stopped-object-frame" will not be drawn, so you don't have to worry about overlapping/confusing coloring.
In the attached model, a colored rectangle is drawn beneath the processors depending on their state (processing - green, blocked - orange, breakdown - red, scheduled down - grey).
color-indicators-state-fm-22-0.fsm
leelichou1112
Is there any other way to directly replace the original yellow frame?
joerg_vogel_HsH
@立洲, I would try it in the SDK and develop my own processor.
joerg_vogel_HsH
The mechanism is controlled in MAIN:/project/library/FlexSimObject>behaviour/cppfunctions
Involved nodes are onDraw(treenode view) and drawStopped(double red, double blue, double green).
An event of stop calls by onDraw the function drawStopped. You make copies of them in objects, which you want to customize to bypass default library inherited setups. Naturally you do it in the objects same attributes tree path of cppfunctions. By calling drawStopped you pass color RGB-values. But you can alter them also in drawStopped.
moehlmann_fe
Observer
Observer
Do you mean visually (display a frame and not a plane) or functionally (only display the frame when the processor is stopped)?
For the first case, you can draw multiple rectangle that together form a frame.
In the second case, you can what Jörg suggests and overwrite the default drawStopped code for the processor.
julie_weller
Hi @立洲 , was one of Joerg Vogel's or Felix Möhlmann's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
