How to change the combiner's componentlist dynamically?
zhun_z
Message 1 of 8
zhun_z
[ FlexSim 22.0.16 ]
I try to change the combiner's componentlist value dynamically, but when i change the value, the model seems unnormal , could you help me find the solution?Combiner.fsm
Replies (7)
Message 2 of 8
joerg_vogel_HsH
@Zhun Z, when do you change components list values by global table lookup: before or during combining components?
Message 3 of 8
zhun_z
During combining components:(After pallet be created,before items be combined)
Message 4 of 8
joerg_vogel_HsH
@Zhun Z, you want to update target quantity involved data in a source code. Please look for answers dealing with these combined keywords.
Message 5 of 8
zhun_z
Thx, When I add the code :
treenode TheSum=getvarnode(current, "targetcomponentsum");
setnodenum(TheSum,PalletSize); the model run what I want. At first , I have just set the Table("componentlist")[1][1], why I also need to set the targetcomponentsum value?
Message 6 of 8
moehlmann_fe
The "targetcomponentsum" variable is used to check if the combiner has pulled the needed total quantity and can thus start the process. Probably so it doesn't have to iterate through each row of the component list after each pull for this check.
Message 7 of 8
zhun_z
Get it,Thanks!
Message 8 of 8
Jeanette_Fullmer
Hi @Zhun Z, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
