How to change the actions of operator
sheng_xin_w
sheng_xin_w
[ FlexSim 20.0.10 ]
我想知道如何讓操作員執行flexsim內置動作以外的動作,例如蹲下移動盒子。我迫切需要知道,謝謝任何答案!
john_michael_f
Question:
"I want to know how to have the operator(s) in FlexSim do other actions/movements. For example, squatting down when picking up a box."
Answer:
If you want to change the basic animations when the operator is standing, walking, and walking with an item, you can select different animations in these three drop-down lists.
如果要更改基本操作人走路或站立的行動,你可以用這裡的三個下拉列表來選擇新的動畫。
If you want to select an animation when the operator performs a task (i.e. picking up a box), select the operator and click the green "+" icon below "triggers".
如果要選擇操作員執行任務時的動作,先點擊操作員和點擊 "triggers" 下的綠色 ”+“ 圖標。
Then select the task/event you want to trigger the animation.
以後要選擇你要引發操作員行動的事件。
Then click the next green "+" icon, visual, start animation.
以後要點擊下面的綠色 "+" 的圖標。
Click the arrow next to the "animation" box, and select the animation you want the operator to perform.
點擊“animation box"右邊的箭頭。選擇你要操作員執行的動作。
If you want to create more advanced custom animations, you can look at this page:
你要創造比較高級的定制動畫,請看看這個網頁。
https://docs.flexsim.com/en/22.0/Using3DObjects/CreatingCustomObjectsAnimations/CreatingCustomAnimat...
john_michael_f
Hello, @Sheng_xin W, was this answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
sheng_xin_w
thank you so much!that's very helpful!
