how to change label of flowitem as it exits a processor
arindam_mahata
arindam_mahata
[ FlexSim 18.0.0 ]
we can use setlabel on exit trigger but my problem is not about changing labels of all the flowitems exiting.suppose there are two items having label say "A" with values 1 and 2 and i want to change the value of item having "A" value=1 to 3.plz help
mischa_spelt
If you use the standard "Set Label" trigger option, and click the little 'Code' button to its right, the code-behind for that option will open and show you a line such as
involved.labels.assert(labelname).value = value;
which does the actual setting of the label.
You can change this to something like
if(involved.labels.assert(labelname).value == 1) {
  involved.labels.assert(labelname).value == value;
where the additional if clause will check if the current value is equal to 1 or not.
Or you can replace the whole code by something simpeler
Object item = param(1);
Object current = ownerobject(c);
int port = param(2);
if(item.LabelOnItem? == 1) {
	item.LabelOnItem = 3;
but then you will not be able to modify it from the popup anymore.
arindam_mahata
thank you sir
francois_g
Hello @Mischa Spelt ,
I tried to use your code to change just one label of one product as asked in the question at the top. So I wrote the code below but nothing happened with my flowitem. The Labelname of my first item stayed at 1 after processing.
I also used your second code : Label name doesn't change.
Have you another solution to suggest ?
Thanks for your response
  involved.labels.assert(labelname).value == 3;
mischa_spelt
Hi Françios. In the second line, you have a comparison instead of an assignment. Replace the == by an =.
Actually you don't need to assert the label twice: when you get into the if it will definitely exist so you can just write it as
  involved.labels[labelname].value = 3;
