- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 17.0.0 ]
Hi all,
In my fluid model fluid from tank 1 will enter into fluid mixture and the steps in fluid mixture will carried out then the fluid moves to fluid processor finally convert into item.
I have done coding on Fluid mixer to update the Mixer step and mixer Recipe .The update will done when the output content reach 100 based on my coding. The code work fine better ,the problem which i am facing is when the update is done the input port of fluid mixer number will changes from 1 to 2 once this happens the fluid is not flow from input port 2.I don't know why the fluid is not flowing from input port 2 when the output content of fluid mixer reaches 100.
Please help me to solve my issue with this fluid model. i have attach my model for your referencefluid-model.fsm
Thank you in advance for your answer
