How to change default label value for 100 objects?
rajankur6494
Message 1 of 8
rajankur6494
[ FlexSim 23.0.0 ]
Hi Team,
I am having 100 objects in my model. I am defining label "Type" for each object and I would like to change it to unique value for each object.
Current Process:
1. I have to select every object and change the label value
2. Tick automatically check box
3. Press save button
4. Repeat for other objects
Is there any better way to do it fast?
Thank you!
03.04.23_Define_Label_Value.fsm
Replies (7)
Message 2 of 8
moehlmann_fe
You can use the property table to change label quicker.
Message 3 of 8
rajankur6494
Hi @Felix Möhlmann,
Thanks for your quick response!
I am getting your point. But how can we tick check box and press save button for all objects so that value can be changed?
Thank you!
Message 4 of 8
moehlmann_fe
If you select all objects (draw selection while holding shift - all selected objects will have a red outline) and then toggle the option on one of them, it should also change for the others.
In version 23.0 the default value will automatically be adjusted when you do this while the model time is 0.
Message 5 of 8
rajankur6494
Ok, thanks! @Felix Möhlmann
Message 6 of 8
jason_lightfoot_adsk
Or use Templates.
Message 7 of 8
rajankur6494
Hi @Jason Lightfoot,
Can you specify which template are you indicating for?
Thanks!
Message 8 of 8
Not sure I understand your question. You create templates for any object or structure containing objects. Here's the description of th e section in Properties: https://docs.flexsim.com/en/23.0/Reference/PropertiesPanels/GeneralPanels/Template/Template.html#tem...
