[ FlexSim HC 5.1.0 ]
Using Flexsim Healthcare, I was wondering if it is possible to automatically connect a number of selected locations to the travel path network based on the proximity of nodes in the travel path network with respect to individual locations in the selection set.
In other words, for a single selected location, the General Properties window provides a boolean option as "Connect to Path" which allows for automatically identifying the closest node in the travel path network to the selected location and creating a connection between the node and the selected location.
However, I was wondering if there is a way to use this functionality for multiple selected locations automatically (like a loop applied to each location in the selection set) so that the closest node in the network per location is identified and a connection is made.
Thank you,
Alireza
