- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 21.0.3 ]
Hello Everybody,
I am working on a model in Flexsim in which I would like to automatically create labels in a storage system based on the number of pallets that I store in the slot. I have used this code and it works:
If I am not mistaken, with the code above, every slot address has two labels: SKU1 and SKU2.
In another code I would like to select the address of the slots and change the value of the labels that I have created above. I get the address of the slot from labels on my token that indicate the number of corridor, level, bay etc. and based on a condition I decide whether to assign the value "token.UDC.sku" to the slot label SKU1 or SKU2. If I am storing the first pallet, then the label SKU1 of that slot should be equal to the SKU of the pallet (token.UDC.sku). If I am storing the second pallet, I would like to set the value of the slot label SKU 2 equal to the SKU of the pallet (token.UDC.sku).
If I have three stored pallets I would need three slot labels (SKU1 SKU2 SKU3) and I would need to expand the code above to cover the condition if(token.cpal == 3). Since the number of pallets in the slot can vary, I wanted to automatize this system and I have tried to write the code below.
The problem is in the way I call the label of the slot. If I call it directly by its name (SKU1 or SKU2) it works but if I use the last code that I showed, it does not work because I cannot refer to the label of the slot address by using "concat...".
Does anybody know how to solve this problem and how to refer to a slot label without directly writing its name in the format .labelname?
Thank you so much for your help!
