How to assign specific colors depending on the arrival time
BAYAN
BAYAN
[ FlexSim 23.2.3 ]
build upstream of a small Pill Bottles manufacturing facility, there are four different pill types of drugs
“A, “B”, “C”, and “D”
All the labels (the Bottles’ information) will depend on the transactional data and will be assigned to each Pill Bottle once it is created
At first the “PillBottleGenerator” will create the Pill Bottles depending on their arrival time and their color that is in the “Color” column in the transactional data
Create the Pill Bottles depending on their color that is in the “Color” column in the transactional data
The colors are (blue, brown , green, orange, pink, purple, red, yellow)
I have created the generator, and from the flow item bin I picked a pill bottle
but I am struggling in how to match the colors for the bottles with the transactional table that contains the arrival time, drugtype(string), quantity (integer)
and how to make the color changes depending on the arrival time specifically
moehlmann_fe
Generally you would assign a label to the items when they are created that determines their color and then use the "Set Color by Case" option to change the color of the item.
If the items are created in a 3d source, a good place to do this is the "On Creation" trigger.
If they are created through Process Flow, the color would be changed in a "Change Visual" activity.
Jeanette_Fullmer
Hi @Baya, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
