How to address an item inside container?
edwin_purwanto
edwin_purwanto
So, I wish to by percentage delete the item inside container (say 30% will be lost, but container will remain).
How do we address the item inside container? "item" only address the container.
Best regards,
Edwin
chanykE2WUT
@Edwin Purwanto
You can use rank(obj, rank_number) to point at any item inside the obj (e.g.item) at the rank.
David
edwin_purwanto
Hi David, thanks for your help. Furthermore, is there any command to selectively delete flowitem?
jing_chen
Use rank() to find out the object you want to delete and use destroyobject() or moveobject()(to a sink) to delete it.
sachin_tandulkar
@david.chan
I am trying to access the part inside the container as the cycletime for the machine is based on the part inside the container.
So i used this as per the suggestion you made.
treenode Part=rank(item,1);
This is returning "NULL" value. Is there any other way to do it, or I did something wrong.
chanykE2WUT
@sachin tandulkar
I am not sure when went wrong, unless you can attached a small model to illustrate it.
David
chanykE2WUT
@sachin tandulkar
I have added an example here. One just using 3D and another with PF.
David
read-cycle-time-from-an-item-inside-a-pallet.fsm
