How to add trigger to 3D object created with flexscript?
jkhedekar
jkhedekar
[ FlexSim 23.0.15 ]
I am creating a list of 3D object Queue with flexscript using createinstance() function. For each of it I want to set trigger on enter and exit while I create them to avoid adding them later manually. How can I achieve it?
joerg_vogel_HsH
Compare object tree with and without specified triggers. Analyze trigger nodes in tree about datatype and data node.
Alternatively create a template with activated triggers and use this later. You can also put customized objects in a custom library and load it later to a new model.
perhaps you can edit a property table or do a query about a property table to insert missing triggers.
arunTTT2P
Use setproperty() to add triggers by code. This will work in future versions also.
Object Queue =Model.find("Queue1");
string y ="Object current = param(1);";//code as string
Queue.setProperty("Triggers.OnEntry",y);
jkhedekar
Exactly what I was looking for. Thank you!
