How to add littering?
amit_b3
amit_b3
[ FlexSim 22.2.0 ]
Hi I am new in niche and just started to use this software, in case how we can add littering in our simulations. It just a factor which is very much associated with our system. We make plastic pots for plants, and there is a lot of littering in case I want to adjust it how can I do it. I am a newbie?
joerg_vogel_HsH
Littering is still output. You can for example use an output setting of a processor to send a percentage amount to a different destination then your products.
Your processor must have then at least two output port connections.
There are templates in Send To function for this kind of scenario.
You can also set up an Empirical Distribution in the toolbox which returns discrete values for output port numbers. You would choose this statistical distribution in Send To function then. But this only a workaround of the template in a processor Send To function.
Edit:
andrew_o2
Hi @Amit B3, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
