How to access the mode staytime of processor ?
PDKG
PDKG
[ FlexSim 23.1.0 ]
I want to display the mode staytime of processor.(Note: "Mode" means the staytime which appear
  • Maximum frequency).
How to develop the node ? or what command I can use? thanks for your answer!
joerg_vogel_HsH
It should be a statistic red pin drop out of statistics property.
default-processor-statistics.jpgTypically it is a difference of model runtime between item is exiting and entering an object. You can compute it easily in triggers of objects or by event driven activities in process flow. Therefore you store the entry time in a label of item or token and build the difference to an exit event or trigger. To show staytime values you set them in a tracked variable.
PDKG
How can I get this exact variable when the model is running through this Histogram dashboard?
Jeanette_Fullmer
Hello @PD,
I do not understand. Joerg has shown you exactly how to get this...
Select your processor. Look in the properties panel under the Statistics tab. Next to the Staytime statistic select the pin icon. Then select the dashboard you want to pin the statistic to and the exact statistics format you want (it doesn't have to be the histogram). Then look in your dashboard for the chart.
carter-walch
Hi @PD, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
