How i create it with rfid
hadez_m
hadez_m
[ FlexSim 20.0.0 ]
How i create Model simulate counting of item stock using RFID. Need 50 pieces of item connect to 50 RFID tags ID. The model is divided into 2 parts. 1. Gold that has not been counted 2. Counted item When scanning RFID tags, item in part 1 move to part 2. RFID tags similar to barcode, can identify item that has not been counted and want to be displayed on user interface.
thank you
joerg_vogel_HsH
Hi @HadeZ M, welcome here at answers of FlexSim, a markable workpiece of simulation software.
There is already a similar question, I answered. RFID.
The counting of labels is done by incrementing another label upon an event. If the counting has been accomplished you should set another label at tested item. Then you can later check if you still need to test the item. You do this as I have written in triggers of objects that transfers, stores or releases items. And as I have said, too, it is a basic mechanism.
If you are not familiar with triggers and labels, I suggest you do some tutorials in the manual and/ or watch some video tutorials of FlexSim.
