How do you zoom in dashboards?
ITAsset
ITAsset
[ FlexSim 16.0.1 ]
I'm still new to FlexSim but this has been driving me crazy....how do you zoom in and out when you are trying to view a dashboard?
Matthew_Gillespie
Dashboards don't zoom. You can always increase the size of dashboard widgets and increase the size of their properties (like text size).
Matthew Gillespie
FlexSim Software Developer
joerg_vogel_HsH
You can undock the dashboard and increase the size of the floating window. Then you can change the size of the widgets as Matthew mentioned. You can even move the widget beyond the edges of the window to look at a larger part. If you have a line chart or time plot you can change the width of the bottom slider and then the line chart is scaled to the width of the slider.
ITAsset
Its not so much the size of things I want to change, I just find it easier to navigate around if I can zoom out then pick a new area to zoom into as can be done in process flow. Like I said, I'm new, I'm still getting used to how things are setup.
joerg_vogel_HsH
Then the answer of Matthew is the only one you can get. Another approach is to build several Dashboards and switch through them as tabs.
