- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim HC 5.1.0 ]
As you're importing one model into another, sometimes it might be necessary to not just move the imported model back and forth or side-to-side, but rather to rotate the entire model so that it faces a different direction for better placement in the first model. Using today's methodology, selecting and importing one model into another is a breeze. However, if you select any object in the imported model while the entire model remains selected for importing, and you use the directional arrows for that object to rotate the entire model, each object rotates on its own axis (See Rotate 1 and Rotate 2 below). Moreover, the path network doesn't rotate at all. How do I select and rotate the entire model on its own axis rather than on the axis of any given object in the model?
