How do you get a reference to the 3D Model view?
aaron_c
Message 1 of 8
aaron_c
[ FlexSim 19.1.0 ]
I want to follow different objects in first-person view at different points in my Process Flow. I found a reference here
https://answers.flexsim.com/questions/45622/ser-view-on-video-recorder-as-first-person-from-op.html
in which @Jacob Gillespie mentioned:
"function_s(view, "follow", object)"
and
"function_s(view, "setFollowFirstPerson", boolean);".
This looks like what I need, but I can't figure out how to get Jacob's "view" reference.
Replies (7)
Message 2 of 8
Matthew_Gillespie
You need to get a reference to the 3D view you want to tell to start following something. This line of code will get you the first open 3D view:
views().find("active>Documents/Perspective/1+/~")
If you had multiple 3D views open and you wanted to set the follow setting on all of them you could do something like this:
treenode perspViews = views().find("active>Documents/Perspective");
for(int i = 1; perspViews.subnodes.length; i++) {
	treenode view = ownerobject(perspViews.subnodes.value);
	function_s(view, "follow", object);
Matthew Gillespie
FlexSim Software Developer
Message 3 of 8
Jacob_Gillespie
If you want to set it to follow in a first person view then add this to your code after calling the follow command.
function_s(view, "setFollowFirstPerson", 1);
Message 4 of 8
aaron_c
Works perfectly! Thanks!!
Message 5 of 8
yehua_z
Hi, @Matthew Gillespie ,
May I ask where to put the codes at? Thank you
Message 6 of 8
Matthew_Gillespie
@Cass Z What are you trying to do?
Matthew Gillespie
Message 7 of 8
yehua_z
so in my model, the source "on creation" triggers different labels on different boxes, and I want to follow one specific type number. Thank you
Message 8 of 8
jason_lightfootVL7B4
Then you're going to put the code in the source oncreation trigger I guess or at the point you want to set the follow. If you have multiple objects of the follow type then you might want to set a global variable to the item you're following and then only activate the follow on a new items and set the variable again, when the global variable is NULL.
