How do I track each product's entire lead time?
wei_ting_l
wei_ting_l
[ FlexSim 18.1.2 ]
I want to track each processing unit's lead time(from the time it enters the system to the time it is being sat in the inventory station). In other words, the queue time for each station+processing time for each station. I want to keep track of each processing units' lead time data. I tried using the dashboard options, but still have not find the options.
joshua_s
You want to take a look at the Staytime statistic for a processor, if you have multiply processors chained together, you can uses zones on process flow to get the total lead time.
emily_hardySTLSK
You can use the composite staytime graphs to track how long an object is between certain objects. In the attached model, I tracked the amount of time between entering the first queue and exiting the last processor. I used a histogram but you can use other graphs as well.
wei-ting-lead-time.fsm
