How do I stop the item when it arrives the first decision point, then send it
alejandro_ulises_tp
Message 1 of 8
alejandro_ulises_tp
I want to stop the item in the first decision point, then analyze which processor is available and then send it, and once the item leaves the processor send the another flowitem, anyone can help me?
run-test-ac2-ultimate.fsm
Replies (7)
Message 2 of 8
tanner_p
This can be modeled using Process Flow. Are you familiar with Process Flow? I'd be happy to make an example model for you to demonstrate how it works.
Message 3 of 8
isaac_l1
Is this what you are looking for?
decision-point-example-flexsim.fsm
Message 4 of 8
alejandro_ulises_tp
I just started studying flexsim for two weeks from the manual, I'm not familiar with the process flow, if you can make a model to demonstrate how it works I would be very happy Tanner!
Message 5 of 8
alejandro_ulises_tp
What!!! amazing Isaac! that's what I was looking for! so the answer was a process flow, I think I need to investigate more on that subject, I'm starting right away! thanks!!
Message 6 of 8
isaac_l1
@Alejandro Ulises TP
I'm glad it worked! The process flow tutorials in the user manual are very helpful. We are also happy to help you if you have any questions.
Message 7 of 8
tanner_p
Hopefully the model from @Isaac Litster can help!
Message 8 of 8
alejandro_ulises_tp
Thanks! I'm starting studying the process flow from the manual
