How do I set a default position to my operator when he is waiting for a task?
1211496
1211496
[ FlexSim 24.0.2 ]
nilP8GEZ
you can do it with 3D triggers using the resource available on operator triggers:1713953801446.png
Then, you can decide if you want the operator to go to a specific position or to an object (home position):
Thanks.
joerg_vogel_HsH
If an operator is not connected on a path network, then you can set a reset position. Right mouse button menu > edit > set reset position
If you want let him to go to a location, while a model runs, can you let him do a travel task in process flow to a location or an object.
If you have done your logi in 3D Model, then you have an On Resource Available trigger in your operator. There you can choose a template to let him travel to a home location.
Jeanette_Fullmer
Hi @Afonso Silva, was one of Joerg Vogel's or Nil Ns's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
