How do i selectively combine same type of items together from using a combiner?
akila_indeewara_kulathunga_wad
[ FlexSim 24.0.2 ]
Selective processing.fsmHello, I need help to selectively combine using a combiner. I have several queues with different types of items. I need the combiner to combine similar types of items together. For example, if the combiner combines 100 of Type 2, then I need it to combine 100 of Type 7 and so on. I have attached a sample model of what I want to do.
joerg_vogel_HsH
This is a default option by an on entry trigger template to update components list by a global table.
recently I attached an example model here.
joerg_vogel_HsH
If you are able to write some conditional source code evaluating the port items are going to be pulled from, you can activate pull option of input property. You set for input ports greater than number one items going to be pulled by a label value of first entered item directly matching your input port connected to right queue.
Jeanette_Fullmer
Hi @Akila_indeewara_kulathunga Wad, was one of Joerg Vogel's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
