How do I move items down to conveyor belt?
tee_hiett
tee_hiett
[ FlexSim HC 5.3.4 ]
I am using Machine B as a multi processor but the items float above the conveyor belt. How can I move these items down to the conveyor belt?
Tee
regan_blackett
Click on your Machine and look to the properties panel on the right. Find the 'Triggers' section on go to 'OnEntry'.
Click the Edit button to the right of the trigger
Click 'Add new trigger instruction' button and choose Set > location, rotation or size
Choose 'Location' from the 'Set:' dropdown menu, select 'Current Value' for the 'X:' and Y:' dropdowns. Type 1.02 into the 'Z:' field.
Reset and Run and that should do it.
tee_hiett
Thanks Regan, that did it!
