How do I know the distance a taskexecuter travels?
rafael_sm
rafael_sm
[ FlexSim 20.1.1 ]
How can I know the distance a taskexecuter travels from one node to another node
and if I can present it through a table or dashboard
cai_c
check this out.
when the taskexecuter arrival some node,record the Total Travel to the table or some lable,then you can get the distance u need.
mischa_spelt
If your task executer is already at the correct start node, you can request the distance to another object, network node, control point, etc. using the distancetotravel command:
Object te = model.find("TaskExecuter1");
Object destination = model.find("Object_NN_or_CP");
double distance = distancetotravel(te, destination);
If you are specifically using the AGV network, you don't even need to have a task executer to calculate the distance between two control points along the network; you can use cpdistance:
Object cp1 = model.find("ControlPoint281");
Object cp2 = model.find("ControlPoint94");
double distanceTo = cpdistance(cp1, cp2);
double distanceBack = cpdistance(cp2, cp1);
Ben_WilsonADSK
Hi @rafael.sm, was mischa.spelt's or cai.c's answer helpful? If so, please click the red "Accept" button on one of their answers. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
