How do I import an image in the 3D model?
jyhjeng_d2
jyhjeng_d2
[ FlexSim 22.0.1 ]
Hi:
I am reading a book, titled "simulation software primer", in page 62, it showed importing a layout as shown.
I did try to import it via Filename drop-down menu in the Texture section of the Display tab as shown.
But it did not work. The flexsim file is as shown.
Primer_2-1B.fsm
The correct result is shown below.
Its flexsim file coming from the primer book is below.
Primer_2-1A.fsm
Is it because mine is a trial version of flexsim, and importing an image only works for the license version?
FelixMoehlmann
After selecting the file you want to add as texture click into the File Path field again and then out of it. That should make FlexSim actually load the image.
Maybe this feature was not available yet when the book was written. But the preferable way to add a layout to a model would be as a model background in the toolbox.
jyhjeng_d2
The model background method works. Thanks.
