How do I get the patient's provider connected to token in Create Token?
tee_hiett
tee_hiett
[ FlexSim 21.2.0 ]
ER Model Notes_1.fsm
In the Create Token activity in the MD Exam set of activities In the attached model, how do I get the MD connected to the token in the"Token Created" Activity? The created token goes through the activities in the MD Recorded Notes activity set but the MD stays at the exam table.
Thanks for the help.
Tee
Matthew_Gillespie
If you check the Label Access on Parent Only checkbox on the Create Token activity then it will all work like you want. Checking that box makes the child token act as a proxy for the parent token and you don't need to worry about acquiring or releasing resources from the child token since it's all treated as if it were the parent token.
er-model-notes-1_mg.fsm
Matthew Gillespie
FlexSim Software Developer
ryan_c10
Hello @Tee Hiett,
I made some adjustments to your model, so it should now work as you intended. The main things I had to change were just some minor settings in some of the process flow activities you were having trouble with. Here's the updated model: er-model-notes-1-rc.fsm
I hope this helps! Let us know if you have further questions!
connor_a
Hi @Tee Hiett, was one of Matthew Gillespie's or Ryan Clark's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
