How do I create a multi-dimensional array?
Matthew_Gillespie
Autodesk Autodesk
Matthew_Gillespie
[ FlexSim 17.0.0 ]
Matthew Gillespie
FlexSim Software Developer
Matthew_Gillespie
In FlexSim 2017 we added a new Array type that holds Variants (a Variant can hold an int, double, string, treenode or Array). This allows you to store an Array as an element of another Array and, thus, make multi-dimensional arrays. There are a few ways you could do this:
Assign an array to another array element
Array myArray = Array(5);
myArray[1] = [1, 2, 3];
Push an array onto another array
myArray.push(["Yes", 5, "No"]);
Fill the array with another array (The fill command puts the given value into every element of the array)
myArray.fill([1, 2, 3]);
Accessing Elements
Once you have a multi-dimensional array set up you use bracket notation to access individual elements.
int x = myArray[3][4];  // Gets the value of the 4th element in the array in the 3rd element of myArray.
myArray[1][2][3] = 5;  // Sets the value of the 3rd element in the array in the 2nd element of the array in the 1st element of myArray.
Matthew Gillespie
