How do i consider process flow for scenario calcualtion?
gokulakrishnan_k2
gokulakrishnan_k2
[ FlexSim 20.2.2 ]
Greetings,
If I want to create a scenario with a process flow variable ( like how many objects entered, created) what should I do? Variable I want to consider is create object by process flow using a global lookup table.
Is it possible? or i can consider the object variable in which item is created?33458-1603105867426.png
joerg_vogel_HsH
I would consider to build a model with all objects already present. Then I deactivate objects in scenarios, which shouldn't be involved. By this the model can be compiled completly on reset and I don't run into problems when a function works only after an reset.
Ben_WilsonADSK
Hi @Gokulakrishnan Kandasamy, was Jörg Vogel's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
