how do I change from number to process name on the left side in dashboard?
HasanID17
HasanID17
[ FlexSim 21.2.4 ]
moehlmann_fe
Have you made any changes to the chart and/or underlying statistics collector? Because those look like ID numbers generated by the "getID()" method of the Statistics Collector. It seems that the display format of the object column in the Statistics Collector is not correctly set to "Object".
If this doesn't help you, can you attach the model?
