[ FlexSim 19.2.4 ]
[ FlexSim 19.2.4 ]
Are you using Time Tables for defining what times they are available? If so, you can just assign a specific Time Table to each subgroup.
Each Time Table can have a unique function that tells the members when they are available or not.
Hi Matthew,
In 19.2.4 I found out I could not use the repeating event button, after several days in the simulation it would not follow the command. Zac mentions hopefully in release 20 this is fixed
That should be working. If you create a new question and attach the model demonstrating the behavior you describe, we can look at it and see if it's a bug.
