How do I access lane conveyors from merge controller
joe_hugan
joe_hugan
[ FlexSim 16.0.1 ]
How do I reference the individual conveyor lanes that are being controlled by a merge controller so I can set different release criteria for each lane that changes as the model runs?
anthony_johnsonT83CM
Looks like that was an oversight.
Instead of accessing the conveyor objects, you could try storing relevant data on the merge controller itself, through something like a label table.
If you absolutely have to have access to the conveyor, you can get it with the command:
ownerobject(tonode(getnodenum(rank(getvarnode(merge, "slugBuildLanes"), laneNum))))
Although I'm always hesitant to suggest digging into tree internals because it can cause compatibility issues if/when we change those tree internals. So, use at your own risk.
joe_hugan
Thank you Anthony
joe_hugan
Thank you Anthony
Hey Joe,
This forum works a little different than our other user forum in that each "Answer" is meant to be an actual answer to the question, not a reply to a previous post. Post-reply conversations are meant to be done in the comments of each answer. This makes answer finding easier for people who are skimming. So I've converted your answer into a comment.
