How create subnodes using DLL Maker
sergio_v6
sergio_v6
[ FlexSim 21.2.3 ]
I want to create a subnode using DLL Maker, using flexscript is like this:
treenode node = node("MODEL:/Tools");
node.subnodes.add();
node.subnodes[node.subnodes.length].name = "MTBFMTTR";
There is a command in c++ DLL Maker (like CreateInstance()) that i can use to do this?
Thanks and regards!
philboboADSK
This is the FlexScript API reference: FlexScript Class Reference (flexsim.com)
The FlexScript API is not accessible in C++ using the DLL Maker.
If you are using the DLL Maker, use the global Command Reference: Alphabetical Command Index (flexsim.com)
Those functions are visible to both FlexScript and C++.
To add a node, use nodeinsertinto() or nodeinsertafter(). To create an instance of a class object, use createinstance().
Your FlexScript code above would be the following C++ code in the DLL Maker:
nodeinsertinto(node);
setname(rank(node, content(node)), "MTBFMTTR");
or more succinctly:
setname(nodeinsertinto(node("MODEL:/Tools")), "MTBFMTTR");
or cleaner:
treenode toolNode = node("MODEL:/Tools");
treenode newNode = nodeinsertinto(toolNode);
setname(newNode, "MTBFMTTR");
Phil BoBo
Sr. Manager, Software Development
sergio_v6
Thank you Phil, it worked!
