How can include AGV library in flexsim7?
rita_l2
rita_l2
I try to use AGV in flexsim7. When I click online-content, it will flash back.
Is there other way to download AGV library?
tanner_p
@Rita L2, Are you able to use the AGV library? There should be AGV modules available in at least FlexSim 7.7, if not earlier versions.
philboboADSK
Starting in FlexSim 7.5, the AGV Module was included in FlexSim's installer.
When you run the installer, check the box to install the AGV Module:
If you didn't check that box, uninstall FlexSim 7.5 and reinstall, checking the box.
The AGV module is no longer distributed as a separate installer. It is included with the standard FlexSim installer.
The earliest version of the AGV module was a separate installer and worked with FlexSim 7.1. There was also another version that worked with FlexSim 7.3 that was a separate installer. Neither of those separate AGV installers are available for download anymore.
Phil BoBo
Sr. Manager, Software Development
