How can I transfer a object from one transport to another transport?
jirawat_j
jirawat_j
[ FlexSim 19.1.0 ]
I'm trying to create a model that allows the transport/task executor to transfer the object between the two transports. Does anyone know how to do it? Please help me.
sebastian_hemmannE3JAU
I think synchronizing tasks is what you need.
Attached a small example model. You can go through the Activitys to see what I did.
Please go sure, that you have to call both operators and there has to be a point, where they meet. I did this quite easy for this example, but I think it is ok to show you how it works basically.
flexsim20191-handover-example-sh.fsm
jirawat_j
I tried to do the same as your example in the case between a transport and task executor. However, I got an error while I ran the model. Can you please tell me what's going on and how to fix it?
Here're an attach file and photos
process-flow-of-transport-and-taskexecutor.fsm
kishan_j
hi,
In the push to list activity push value is token.item and assign to is token.puller
jirawat_j
Yo bro! you really killed it. Thank you so much
Sorry for my late reply. Yes you have to find a good solution to transfer the information about the item from one token to the other one.
There are many different ways to do this, I only tried to support one possible solution.
