How can I set the start and end height of a conveyor in code?
axel_kohonen
Message 1 of 12
axel_kohonen
[ FlexSim 16.0.1 ]
I would like to set the conveyor start and end height (and other parameters) of a straight conveyor in code. The start and end heights are the values underlined with red in the image below. I could not find the parameters in the model tree. Where can I find them or do this?
Thank you!
Kind regards,
Axel
Replies (11)
Message 2 of 12
Matthew_Gillespie
This is the code that the Quick Properties panel ends up using:
function_s(conveyor, "setZ", 1, 0);
function_s(conveyor, "clearNonLockedPoints");
function_s(conveyor, "notifyEdgePointsOnEdgeMoved");
function_s(conveyor, "finalizeSpatialChanges");
The 1st parameter of the setZ function is the new z location and the second parameter is which end of the conveyor (0 or 1).
Matthew Gillespie
FlexSim Software Developer
Message 3 of 12
axel_kohonen
Thank you Matthew! I concluded that you need to call rows 2-4 only once after setting both the start and end height. How did you know how the Quick properties panel did it? Did you use the right click on quick properties -> View -> Explore structure approach? I tried now, but could not find the needed code anyhow.
Message 4 of 12
joerg_vogel_HsH
The modules depend on hidden DLL-functions. The code
has been introduced by Phil Bobo at some threads in the community forum for example in Move Decision Point along the Conveyor by code . The functions are in the library tree in conveyor>conveyor/behaviour/eventfunctions to find, sadly without any parameter to use or comments.
Message 5 of 12
Matthew_Gillespie
I'm pretty sure you'd only need to do it once after setting both. Yes, I looked at the structure and had to follow the function calls until I found this code on a top level panel where it was placed so that multiple fields could use it.
Matthew Gillespie
Message 6 of 12
axel_kohonen
Thank you Matthew and Jörg! Seems that the functions are rather well hidden yes, but good that there are people on the forum that know where to find them if one cannot find them himself.
Message 7 of 12
jing_chen
Hi, Matt
I also want to know if there are some other commands just like "setZ" in function_s which can change other variables of Conveyor, and where can I find these codes?
Message 8 of 12
Matthew_Gillespie
All the functions that can be called with the function_s command can be found on this node for the conveyor class:
MAIN:/project/library/conveyor/Conveyor>behaviour/eventfunctions
Matthew Gillespie
Message 9 of 12
Matthew_Gillespie
See this more comprehensive answer for Getting and setting conveyor end points
Matthew Gillespie
Message 10 of 12
london_mt
@Matthew Gillespie
how do you do this exactly? Doesn't seem to work for me:
It doesn't show anything.
Jarek
Message 11 of 12
Matthew_Gillespie
You're not looking at the right object. You're looking at a ConveyorSystem object, not a Conveyor. Look at the path I referenced above.
Matthew Gillespie
Message 12 of 12
philboboADSK
To get to the library tree, you need to push the Main button in the Tree Navigation panel in Quick Properties:
Phil BoBo
Sr. Manager, Software Development
