How can I set the operator picking from client order?
jinhyeok000117
jinhyeok000117
[ FlexSim 20.0.9 ]
project team.fsmIn process flow, i set the Picker pick the object from client order but the picker doesn't move please help
Jeanette_Fullmer
From looking at your process flow the token reaches the pull from list activity in the sub flow. If you examine the activity and lists you will see that it is trying to pull from an empty list.
Before that in the process flow is a Push to list activity that pushes to a different list than you pull from. The list that it is pushed to ("Picks") is not one you created in the toolbox. It is an internal list. Is this correct? If this is then you need to open the lists advanced options and correct the name of the label fields so they match the labels on the tokens.
Could you re-examine your activities that are involved with your lists and walk through how you intended the lists to be utilized?
Ben_WilsonADSK
Hi @진혁 ,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
