How can I reduce the size of the triangle in DISPLAY_TRIANGLE?
tee_hiett
Message 1 of 8
tee_hiett
I would like to use the triangle to indicate patient waiting for a room. The default size blocks out the view of many patients.
Tee
Replies (7)
Message 2 of 8
Matthew_Gillespie
The size of the triangle is defined in the Healthcare DLL and there currently is no way to change it as a user.
Matthew Gillespie
FlexSim Software Developer
Message 3 of 8
tee_hiett
Sorry about that. Have you considered reducing the default size of the triangle? Why is it so large?
Message 4 of 8
cliff_king
I wasn't aware anyone used that feature. Congratulations on discovering the feature even exists! I will reduce the size of it for you in the next release. Since you're probably the only one who uses it, what size would you prefer? Half its current size?
Message 5 of 8
tee_hiett
Cliff,
I suggest that a triangle of 1/4 the current size would be sufficient to call attention to that patient and the number of patients.
BTW, what is the approximate estimate of the next release of the HC update?
Tee
Message 6 of 8
cliff_king
Sometime between now and the next eclipse (or Halloween, whichever comes first) 😉
Message 7 of 8
Matthew_Gillespie
This was added to 5.3
Matthew Gillespie
Message 8 of 8
tee_hiett
A nice added feature. Thanks for listening and making changes.
Tee
