how can I record different views at the same time with video recorder?
cindy_azuero
cindy_azuero
[ FlexSim 16.2.1 ]
I'm making a video and I want to record various output files at the same time, each one with a different view (ideally using the ones in the view interface on quick properties panel). How can I do this?
kari_payton
@Cindy Azuero I used an external application to record my screen. Like gamers use for youtube.
sam_stubbsYXX86
If I'm understanding your question. You could do this two ways. First, you could just open up multiple instances of Flexsim (your model) and have each instance start recording each of the different views at the same time.
Alternatively, you can create a flypath for each view you've created. Then in your Recorder, create several output files, and assign each one with the corresponding flight path, which correspond to each view.
jeff_nordgren
I think Kari's solution would be the best option. I'm pretty sure that FlexSim can only capture one view at a time. I'd go with 3rd party software as Kari suggests.
philboboADSK
Sam's answer is correct if you are trying to "record various output files at the same time" as your question says.
If you are trying to record different 3D views into a single output file, you can use the Video Recorder's Shared Sequences to add multiple Layers to your output, which can include different 3D views being recorded at the same time into the same output file.
Using this, you can get picture-in-picture output of your model, including 3D views and Dashboards.
See the attached sample model.
Phil BoBo
Sr. Manager, Software Development
