How can I put two different speeds in one crane?
manuel_m43
manuel_m43
[ FlexSim 22.0.0 ]
The idea is to assign different speeds according to the type of product being transported
moehlmann_fe
Observer
Observer
The speed and acceleration values are stored in the crane's "variables" tree.
You can set these using code with the following syntax:
Model.find("craneName>variables/cranespeeds/Part/var").value = N
"Part" should be replaced with which speed you want to set (Gantry, Trolley, Hoist_Lift or Hoist_Drop). "var" should "1" to set the maximum speed, "2" for the acceleration and "3" for the deceleration. This can also be seen in the tree in the "Gantry" node, but for the others the subnodes are not named so they have to be referenced by rank.
To change the speeds depending on item, you could use this in the load trigger of the crane. In that case the expression can be shortened because the crane is already referenced with "current" variable - a reference to the ownerobject of the event, in this case the crane itself.
If you only have a few different types you can use if - else condition to set the speed. With numerous values I'd suggest to use the switch - case syntax.
https://docs.flexsim.com/en/19.2/Reference/CodingInFlexSim/WritingLogic/#flow
In the "Unload" and "Reset" you then reset the speeds/acceleration/deceleration to their default values. Attached is an example model in which items of type 1 (red) are transport with a max speed of 4 and type 2 (green) with a max speed of 1.
ChangeCraneSpeeds.fsm
philboboADSK
Rather than adjusting the variables nodes directly, you should use the Object.getProperty() and Object.setProperty() methods:
Object crane = Model.find("Crane1");
var craneSpeeds = crane.getProperty("CraneSpeeds");
//return craneSpeeds;
craneSpeeds[2][1] = 3; // change Trolley Max_Speed
crane.setProperty("CraneSpeeds", craneSpeeds);
return craneSpeeds;
https://docs.flexsim.com/en/22.0/Reference/3DObjects/TaskExecuters/Crane/Crane.html#properties
https://docs.flexsim.com/en/22.0/Reference/CodingInFlexSim/FlexScriptAPIReference/Tree/Object.html#M...
Phil BoBo
Sr. Manager, Software Development
ryan_c10
Hi @Manuel M43, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
