How can I pick up with a transporter pallets from process flow?
natalia_g6
Message 1 of 9
natalia_g6
[ FlexSim 19.0.0 ]
Hi @Seung Yong Seo , @Braydn T,@Clair A, @Gokulakrishnan Kandasamy, @Phil BoBo , @Yogesh H, @Ben Wilson , @Matt Long , @Matthew Gillespie, @Sam Stubbs, @Joshua S ,
How can I pick up pallets from process flow, I have 3 queue with pallets that has products and I want to pick up the pallets one by one but when I use the loading function it generates a warning , I want to know how can I resolve this problem.
Thanks for your help.
Replies (8)
Message 2 of 9
gokulakrishnan_k2
@Natalia G6 That means you missed to define some of the boxes in the load task sequence. Please check your model.
Message 3 of 9
natalia_g6
Hi, @Gokulakrishnan Kandasamy, @Seung Yong Seo , @Braydn T,@Clair A, @Phil BoBo , @Yogesh H, @Ben Wilson , @Matt Long , @Matthew Gillespie, @Sam Stubbs, @Joshua S
I review this part, but I continue with the problem, I don´t know how to configure the "load option" Thanks for your help .
Modelo de respaldo (3).fsm
Message 4 of 9
gokulakrishnan_k2
@Natalia G6 because your token in the transporter subflow doesn't carry that label value. So please check this option. It will work. Please find the attached modelo-de-respaldo-3 (2).fsm model. there is a little problem with the model you need to update that. 35160-subflow.png
Message 5 of 9
natalia_g6
Thank so much @Gokulakrishnan Kandasamy, your answer was really helpfull, If you dont have problem I woud like ask you something more , when I run the model always one pallet remains in the quee wich transporter and operators does not move it ,and I need to transport all of them, how can I resolve this?
modelo-de-respaldo-3-2.fsm
Message 6 of 9
gokulakrishnan_k2
@Natalia G6 How many pallets do you want to create? based on that you need to model the subflow
Message 7 of 9
natalia_g6
@Gokulakrishnan Kandasamy , I have a label that allow me to generate pallets with a distribution, when I create the subflow I do in base of it, but I continue with the problem
Message 8 of 9
gokulakrishnan_k2
@Natalia G6 if you are creating 5 pallets at a time you should load the same pallets by box but your are missed loading all the pallet. A single pallet is loaded from your subflow.
Message 9 of 9
doris_c
That was helpful. Thank you.
