How can i make that the queue open the output controlled by time?
martin_t4
martin_t4
[ FlexSim 19.0.9 ]
Hello i start to prepare a model in flex sim and my question is how it is possible to open the outputports of the queue 2,11,13,14,15,16 every 2 minuts?
Jeanette_Fullmer
Hello @Martin T4,
You can make a user event that opens the ports by code or by sending a message.
You can select to repeat the event and set it to every 2 minutes worth of model units which in your case is 120 seconds. In the Event Code you can select Close and Open Ports option and set it for each queue.
Jeanette_Fullmer
Hi @Martin T4, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
martin_t4
Perfekt thank you it is wokring
