How can I fill hangers in specific coveyors?
jiseok_y
Message 1 of 8
jiseok_y
[ FlexSim 23.0.0 ]
Hello
I want to start after completely filling the hangers in the A1 to A3 (Elevator 38 to Elevator 30) section. (The space between hangers should be maintained as previously set.)
I tried configuring and applying the Accumulation logic, but the hangers are gathered, but it does not resume.
Is there any good way?
Replies (7)
Message 2 of 8
jason_lightfootVL7B4
At what time are hangers stuck and not resuming? When I run it the hangers all move.
I fixed a label error on DP44, and now non F1cars continue through the system - but you still have exceptions further in the process.
230426-1925-copy_jl.fsm
Message 3 of 8
jiseok_y
Thank you Janson,
However, when the simulation started, there was a space between the hangers,
After stopping the hanger at DP11 above Elevator30, wait until the hanger is full in the A1 ~ A3 section as mentioned above. If it is full, I want to make a hanger move
However, I want to implement the Accumulation logic using DP11, but it seems difficult at the moment.
Message 4 of 8
You just need to stop the item without the delay and then resume the item when another DP28's entries have exceeded a number.
Message 5 of 8
I added the process to hold the hangers at a new DP until DP28 has had 39 hangers pass.
230426-1925-copy_jl2.fsm
Message 6 of 8
jiseok_y
Thankyou jason
could you tell me about New DP? I don't find what you said NEW DP
Message 7 of 8
It's just before DP11 - DP8 I think. It's attached to the process flow shown above.
Message 8 of 8
Jeanette_Fullmer
Hi @David.Y, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
