How can I extract a matrix that rappresents the position in a rack?
alfredo_df2
alfredo_df2
[ FlexSim 17.2.5 ]
I'm working on the simulation of a warehouse. Assigned number of channel, number of level for the rack and capacity of the rack, is it possible to extract a matrix that identifies the rack positions, both free and occupied?
Thank you.
joerg_vogel_HsH
It is a node that contains the data. Level is the column of the table, row is the bay.
alfredo_df2
Oh, thenk you very much. A other question, Can I modify it? For example, if I want to insert initials item before simulation?
joerg_vogel_HsH
@Alfredo DF2
The table is the result of items entering the rack. You can set values on reset, then the cells are internally stated as filled. Maybe you mess up the statistics of the rack.
