How can I create txt file if it does not exist?
manuel_s4
manuel_s4
[ FlexSim 19.1.0 ]
I want to export some data to a .txt file but first I need to check if it exists with command fileexists. If it doesn't, I want to create the .txt file automatically and then fill it out with the data.
Thanks.
Manuel.
JordanLJohnson
If you use the command fileopen(fileName, "w"), and the path is valid, then the file will be created, even if it doesn't exist.
Jordan Johnson
Principal Software Engineer
manuel_s4
Thanks @jordan.johnson, it worked perfectly.
