How can I connect two arbitrary points with a column?
mark_s3
mark_s3
[ FlexSim 22.1.2 ]
I have the coordinates of four points, and those four points could be anywhere.
I can use the "drawline" function to draw lines between points.
However, I don't know how to use the "drawcolumn" function to properly join points with a column?
drawcolumn_problem_V2022_Updae_1.fsm
moehlmann_fe
Starting with the code that Jason provided in his comment here. All that needs to be added is to translate the coordinate system so that the starting point of the column coincides with the coordinate origin. Otherwise, rotating the coordinate system to have the column point in the correct direction would move the starting point.
Then, since you are drawing multiple shapes, the transformations have to be reversed before the next shape is drawn
drawcolumn-problem-v2022-updae-1_1.fsm
