How can I cofigurate a operator to load more than 1 box from process flow ?
natalia_g6
natalia_g6
[ FlexSim 20.2.3 ]
How can I cofigurate a operator to load more than 1 box from process flow , I have a quee with boxes and I want that operator lod 3 boxes an unload in other queue, how can I do it ?
SCHamoen
@Natalia G6 Change the capacity field of the operator from 1 to 3
parker_s
@Natalia G6
https://docs.flexsim.com/en/20.2/Tutorials/TaskLogic/Tutorial3ConditionalTasks/3-1SubflowsArrays/
This link provides a tutorial to have an operator load and unload multiple boxes using lists in process flow. Is this what you're looking for?
natalia_g6
Yes, It was just that I needed, Thank so much @Parker S. It was really usefull, I resolved my problem.
natalia_g6
Hi @Parker S , I have a last question, how can I configure the operator to load between 2 or 3 boxes, for example if in the quee at the end are 2 boxes how I tell to operator to load this last boxes that remain in the queue and are less than 3.
parker_s
Changing the "Require" value in the Pull from List properties from 3 to 2 would allow the operator to pick the 2 remaining boxes.
Additionally, you could change the value to 1 in the case that there might be 1 left in the queue. Request and Require values are similar to maximum and minimum values. If there are 3 items available to pull, they will get pulled. If there are less items, they will get pulled if it is more or equal to the Require value.
