How add Tabs to GUI
How add Tabs to GUI
patryk_u2
Message 1 of 9
How add Tabs to GUI
patryk_u2
[ FlexSim 23.2.2 ]
I would like to create a gui with tabs where I could place buttons, subtitles or trackers. I used tabs for this purpose, only the inserted buttons and trackers do not work, and the subtitles are not visible. Is there maybe another way to do this?
Replies (8)
Message 2 of 9
jason_lightfootVL7B4
When I've done this I've edited pagelist of the tab control which allows you to use standard/common pages along with those that are custom.
Message 3 of 9
Can you post the model so we can see what's happening and how you've set it up?
Message 4 of 9
patryk_u2
I am sending the model in attachments. I want to change values in the table using the trackerTest.fsm
Message 5 of 9
First off, your tabs should be viewwindowtype 102 for the text to display.
I see no buttons.
Your sliders update the global table. You need to add code to the opening of the GUI/pages to set the sliders to the values from the table.
Message 6 of 9
patryk_u2
I just tried it and the sliders do not change the values in the table. Additionally, when I added a button with the close function earlier, it did not close the gui1700553465779.png
Message 7 of 9
patryk_u2
I added button and spinner to change value in GlobalTable1. Unfortunately don't work
Test_1.fsm
Message 8 of 9
Odd - it works for me:
test_GUITabs_jl.fsm
Message 9 of 9
Hi @Patryk, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
