Hi! How can I record simulation data in a table?
caraiman_c
caraiman_c
[ FlexSim 19.0.0 ]
Hi! How can I record simulation data in a table? I am referring to the time dates in which Operator_P1, Operator_P2 and Operator_P3 move with parts P1, P2 and P3 and at the time when each part starts to be processed on each processor.
cercetare-ultim-3.fsm
mitregatomasz90
Hi
In Custome Code block when you click green plus there is an option data and in data add row and data to global table
There You can add row and in which column what kind of data will be.
For time of model You write Model.time. If you want to enter a time period then You have to create label at the begining of the process with value of Model.time and at the end of the process minus it from Model.time
caraiman_c
I got this error. Can you tell me why?
ryan_c10
Hi @caraiman.c,
We haven't heard more from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
