Help with code to increment tracked variable based on token label.
kari_payton
kari_payton
[ FlexSim 17.1.4 ]
Object current = param(1);
treenode activity = param(2);
Token token = param(3);
treenode processFlow = ownerobject(activity);
int bladeType = token.bladeType;
if (bladeType = 1)
	{treenode thenode = TrackedVariable("Blade Type 1 Closed");
	double value = 1;
	inc(thenode,value);
if (bladeType = 2)
	{treenode thenode = TrackedVariable("Blade Type 2 Closed");
	double value = 1;
	inc(thenode,value);
if (bladeType = 3)
	{treenode thenode = TrackedVariable("Blade Type 3 Closed");
	double value = 1;
	inc(thenode,value);
When tokens of a certain "bladeType" finish processing, I have this custom code to count the number of tokens of that blade type that flow through this block and increment the tracked variable by 1. However, each time a token flows through this block, each tracked variable increases. Any ideas what I am missing?
Jacob_Gillespie
Your if statements need to use double equals signs. Like This:
if (bladeType == 1)
kari_payton
Aw man so simple. Thanks @Jacob Gillespie
