Help to manage an AGV's task sequence
stefano_l
stefano_l
[ FlexSim 19.0.0 ]
Hi everybody,
In my model I need to serve, through an AGV, 2 queues called ServiceQueue and ServiceQueue2 according to the First Come First Served (FIFO) method. In particular, if an item arrives in ServiceQueueue, the AGV has to take that item, move it to Storage, take another one of the same type from Retrieval and put it back in ServiceQueue. It should do the same thing with the second queue ServiceQueue2, but running the simulation the AGV's task sequence, while it is serving a queue, is interrupted to serve the other queue.
I think that the problem is in the ProcessFlow logic. Can someone help me please?
service.fsm
I attached my model. Thanks for the support.
zac_h_adsk
@stefano L
Here is a model that has the corrections. The AGV will now pick up box from ServiceQueue, drop off at storage and pick up at retrieval and return back to the same ServiceQueue. In your process flow you were releasing the AGV which allowed it to get picked by another task before what you wanted it to do was completed.
service-agv.fsm
stefano_l
Ok, I realized where I was wrong. Thank you so much @Zac H!
stefano_l
@Zac H, is there a way to merge the activities in AGV TaskSequence for ServiceQueue2 shape and activities in AGV TaskSequence for ServiceQueue shape into a single stacked block?
